Rear Demister
2.9K views 2 replies 3 participants last post by  Magson
#1 ·
Hi all, I have a query regarding the operation of the rear demister on my 2019 1.4 turbo elite.
1.With the setting in the Vehicle sub menu set to auto demist & auto button switched on does the rear demister only come on when the outside temperature is below approx 3 degrees ?.
2. With the auto demist switched off under Vehicle settings sub menu should the rear demister manually be able to switch on at any temperature or is it still controlled by HVAC system to only come at approx 3 degrees still ?
Operators manual does not make this clear wether in auto or manual operation.
#3 ·
There is a button which resembles a "square grill" . It operates both heated mirrors and rear screen heating/demist. At least on my car it does. I believe after a period of time it disconnects itself but I have never kept it on longer than about 5 mins.
