1 - 4 of 4 Posts
Are the any differences between then AFL in SE and exclusiv model's? Are the colour temperature the same on the xenon headlights? as my exclusiv xenons seem a little yellow, not as white/blue as previous cars I've had xenons on
The SE has xenons and the exclusiv has halogens , which explains what you are experiencing . You could always upgrade the bulbs to something like Osram Nightbreaker range . Quite a few vehicles appear to come with barely adequate ( if that ) bulbs these days . Had to up rate the ASX as that was a dim yellow light , that did little to help night vision .
You have AFL units in your signature like I do & I would think thatthey should be the same unitsas thosefitted to the SE. To use another typewould cost too much & involve more work on the production line. Mine seem bright white maybe you have an earth or connectorfault holding them back.
1 - 4 of 4 Posts
