1 - 17 of 17 Posts
Would anyone have any knowledge of replacing the front wiper motor.
After looking through the forum there are a few posts that contain the exact symptoms as mine i.e wipers starting as soon as car switched on,then stopping in a random position then having to be docked by pressing down on the stalk.
The replies all seem to point to a new wiper motor.
Is it something that could be changed myself and what would it entail
many thanks
Discussion Starter · #2 ·
hi
sorry to ask again but could any one confirm if the wiper motor is the correct cause of this as i have seen a couple on ebay that have the correct part number but don't want to buy if there could be another cause. TIA
hi.Thanks for the info looks like it could still point to the motor as they do wipe ok but come on when starting the car even in the off position
many thanks
I replaced my wiper motor a few years ago. It would have been a warranty job, but I could not wait for Vauxhall garage to locate the part, and I did not fancy the mechanic damaging my car in the process of removal/re-fitment, etc. Prefer to do my own repairs generally. Anyway, I found a very reasonably priced motor and linkage on ebay and did it myself. First you need to remove wiper arms, can be a bit fiddly to get them off after removing the nut. Give the arms a tap with a rubber hammer or something similar, helps them to jump off the spindles.
Then remove the plastic water deflector at bottom of windscreen, have a good look at it before removal and it is quite an easy job. https://vauxhall.7zap.com/en/car/j13/c/5/1-0/
Next remove the wiper mechanism, very easy part. https://vauxhall.7zap.com/en/car/j13/p/10/8-0/
PM me if you need any more help.
Discussion Starter · #6 · (Edited)
That's brilliant info.Did have a quick look today and can actually see the part number through the plastic scuttle panel.
Could i just ask if the problems i am having are the same as you had and do the scuttle retainer clips just push in and out.
The symptoms you had were very similar to mine. I spent some time on Google looking for similar problems on other Vauxhall vehicles and it all pointed to the motor. The scuttle clips are a bit of a pain, I used a set of trim removal tools, only a few quid on eBay. I also used small nosed pliers to push up the ones I could see from inside the engine bay. I have had the scuttle out a few times now to do other jobs on the front suspension, so I can do it very quickly now. Just need a bit of patience with the clips and removing the wiper arms. When you remove the wiper arm nuts it is quite difficult to wiggle off the arms. I found that giving them a tap, midway along the wiper arm shaft, helped to get them to move up and out. I believe you can buy a tool that makes it a bit easier.
Discussion Starter · #8 ·
Thanks for your reply i will get on ebay and order one now before they go !!
It's hard to believe the antics of some! :sad:
I have the same problem with the wipers starting when ignition switched on, and also stopping mid screen. Did a replacement motor solve the problem? Thanks.
Vauxhall's in their infinite wisdom no longer supply the wiper motor on its own. It is now only available as a complete linkage and motor assy. This retails at £316.80 inc vat but has over 60 on back order in Europe. Ebay and the like may split them
Discussion Starter · #15 ·
hi.Having just replaced mine with a complete unit i purchased from ebay from a 2016 model.I would say it is easier to change the complete unit than just the motor
Just wanted to add my thanks on this thread. I was having the same issue, and was able to repair the fault in the motor.
A small push-on clip had corroded, which caused an intermittent break in the circuit. Found a video on YouTube which clearly showed how to repair. Easy fix and saved me £200 on a new motor or £50 on a 2nd hand one.
Only expense would be a starlock washer to replace the corroded one and some trim fittings if any break on removal. I used a trim removal tool for the scuttle, a 15mm socket for the wiper arms, a hammer to gently loosen them, a 10mm socket for the linkages and a t30 torx bit to remove the motor. A small screwdriver or pick and a wire brush can help to clean it all up before reassembly. I used a 4mm socket to press the starlock on.
I got hold of some stainless steel circlips in readiness for this job. Will these fit, or will only starlock washers fit in place of the corroded one?
1 - 17 of 17 Posts
