Hi mokka as Dave , no the heko's won't cause any damage , they fit in the window channels, held with double sided tape ( already on ) and 2 metal clips per window , will come off easily when you want to change if you take it easy removing the clips , or you can leave then in and get a new set off eBay , I took a set off my corsa when I changed that a couple of years ago with no problem , hope that helps ...Mokka Mad Dave said:Got the same problem but with my soon to be returned Astra but only with rear passenger window open. My solution was to ban passengers from opening saidbrear window. Was thinking of fitting hekos to tje mokka when i take delivery of my mokka but worried as as its a motability vehicle and im not supposed to cause damage to vehicle. Can anybody tell me if fitting hekos would cause damage.
Thanks ..was thinking of the door sealsI would get someone to sit in the back to double check the door when being driven. If confirmed its the door rather than the window, check that the door is sitting correctly and if so it could be the rubber surround at fault and would need replacing.
