Hello my mokka 1.4T started to blow cold air from heaters, so when I got home and looked under the engine , water is dripping from the back of the engine. Just wondering what it could be,
No, I just had the heating on, then I got home and the temperature gauge was high, then checked under the car and water was dripping, from the back end of the engine, could not see much as it was dark, and not had time today as at work
I would check the coolant level asap and determine how much coolant has leaked. Keep a close eye on the level- the last thing you want is for the engine to overheat.
The next step is to get it checked out by a workshop-unless of course you fancy tackling the problem yourself.
You don't say how old or what milage but the problem could be coolant leakage. If you use the search facility at top centre of the page you will see several threads on this.
