1 - 4 of 4 Posts
Please accept my apologies if this has been asked about before
My 1.6 petrol 2014 Mokka is apparently taking longer to heat up to working temperature and I suspect the thermostat may be stuck slightly open /broken
The gauge shows just below half when at working temperature and the heater temp appears ok however when I switch the heater on the water temp drops slightly but then recovers
My question is does a broken thermostat show a fault code and if so do I need a fault code reader
Discussion Starter #2 (Edited)
Please ignore the above
Recently had cam belt ,water pump replaced all appears to be fine thermostat wise/ temperature wise
Not as far as his wallet's concerned! :eek:
1 - 4 of 4 Posts
