Hi all.
Just bought a 2014 Mokka 1.7cdti, in the last couple of days I have noticed that when I am turning left there is a knocking noise that sounds like it is coming from under the steering wheel towards the pedal area. Also the steering wheel will not return to centre when coming out of a turn, this happens more when I turn left than right, but does happen both ways, I have scoured the Internet but can not find any info on this, all I can find is about power steering failures, any help would be greatly appreciated.
Thanks Dan.
Hi all.
Thanks Dan.
I would check your steering column, it maybe slightly bent due to previous accident damage, garage won't tell you unless you ask, could be steering motor failure, just give a thorough check,, loose bolts, etc
May be tracking set wrong
Can't see that myself, they usually skipping down road, like a kid with a rope, years ago, I had a rover 1.6 before I bought it, I had two new tyres on front, got in drove down road, it was like trying to ride a bull at a rodeo, tyre fitter said tyres have got to wear in first mate, took it to another garage, guy said how the ##@##%,did you drive this, you are very lucky, your tracking is wayway, off line, SORTED, CAR DROVE LIKE A DREAM. just thought I would throw that in, in case some other,backstreet, wannabee trys to pull off the same stunt with someone else, we live and learn.!!!
It’s the caster angle in the steering geometry that gives you self-centring steering. I don’t think it’s adjustable on the Mokka, it’s set during the factory build.
If your car has been in an accident and had damage done to the front suspension it’s a possibility this, and other steering geometry angles, have been knocked out of alignment; only way to tell is by a full steering geometry check.
It’s also possible to get a steering rack damaged by impact at the wheel/hub area which leaves it with high spots and could cause the same.
It would have been helpful if Dan5382 had updated us on his thread which is now two months old?
