1 - 4 of 4 Posts
Hi all
When my mokka has been driven for about 15min or so it
develops a squeeky wheel. This goes away when I tap the brakes then comes back on. My thoughts are worn brake pads but someone has suggested maybe worn bearing. Any thoughts anyone?
Not likely to be a bearing, worn or sticking pads or sometimes just a bit of grit embedded in a pad.
Year and model of car would have helped and is it back or front
Pre X facelift models had problems with the rear caliper dampers, i had my rear 2015 dampers changed
X models had different rear calipers fitted, if it's coming from the front, could be pads or as suggested above
Does the Mokka have those metal shimmes that squeal to warn of low brake pads and could it be that?
1 - 4 of 4 Posts
