I have a 2015 1.4 turbo petrol Mokka. When I switch the engine off the radiator fans comes on and stays on for a long time (>30 minutes). The only way to stop the fan is to switch the ignition on and off without starting the engine. I know sometimes the fan can come on when stopped but it should go off after a couple of minutes when things have cooled down.
Has anyone got any ideas what is causing this please. The power resistor on the radiator was changed 3 months ago because it was open circuit and the fan worked correctly. This fault has only just started.
