1 - 7 of 7 Posts
Hi I am having issues with a p0234 turbocharger overboost fault code on my mokka 1.6 ecoflex causing car to go into limp home mode, I also had a p0402 which pointed to egr which I have replaced for a new one and also cleaned all pipes throttle body and map sensor also checked for split pipes and had a engine carbon clean but still getting p0234 fault code has anyone had this issue with this.
Hi thanks for the reply I have put a can of wynns turbo cleaner through the turbo to try but the code and limp mode still comes on so I'm still at a loss car has only done 30000 miles, I have had a letter for a recall on it so I will see if I can wangle a full diagnostic on it when I book it in.
Thanks for taking the time to reply.
1.4T Boracay Blue
The article pointed in the direction of the dump valve and pipework associated with it. Removing said items and cleaning out would be needed.
I will take a look over the weekend as I'm working all week and try and pluck up the courage to take turbo off as I'm a bit of an amateur mechanic 🤣 everything I'm reading seems to be pointing towards turbo vanes so I will keep you updated again thanks for the info.
1 - 7 of 7 Posts
