I have managed to set the outside temprature tooF any help to set it back to centigrade
Many thanks.
Many thanks.
Have just noticed the outside temperature has changed to F from C, any ideas how to change it back?Cold hater said:I have managed to set the outside temprature to oF any help to set it back to centigrade
Many thanks.
Have done, nothing in there thats lets you change it.Tweev said:Must be in the config. Scroll through the options
Thanks DCB and Seamaster, easy when you know how, job doneseamaster said:As previuosly stated by Spireite, refer to page 85 of owners manual which says:
Vehicle Information Menu Press the MENU button to select the Vehicle Information Menu,
or on Uplevel-Combi-Display select X. Turn the adjuster wheel to select a submenu.
Press the SET/CLR button to confirm. Follow the instructions given in the submenus.
Possible submenus can be, depending on the version: Unit: displayed units can be changed.
