1 - 10 of 10 Posts
I have had my mokka 64 reg, for 1 month. Yesterday I got a code 82. And the oil % was 5. I have booked car in for a service on Tuesday. Does this mean I can’t drive it till then. Joe
Yes you can drive it .its only telling you the service is due .it is only a gimmick but people believe it but it makes money for the dealer .how many miles have you done since last service.oil is good for 20k .mine says 20% but not getting a service till end of September whether it comes on or not
If you got it from a car dealer I would have asked for a service
Discussion Starter #5
Thanks Swinton. It has done about 6000 miles since last service. The seller put a 12 months mot on the car, and gave me a 6 months warrenty . It is just 12 months since last service. Thanks , joe, ( Bolton)
That's rather a bold statement to make especially regarding a turbo assisted engine, but each individual would have different opinions. Personally I have always changed mine around 10,000 miles regardless whether a service was due.
"Today’s turbos are complex, but they’re still inherently reliable. Less than 1% of turbo failures are due to a fault with the turbo itself, over 90% are oil-related. Correct, clean oil is vital for turbos. A turbine shaft spins up to 6,000 times every second (an amazing 360,000 rpm), in temperatures of up to 950°C, and is protected by just a thin film of oil on the shaft bearings. Any problem with the oil will damage the bearings or oil seals, inevitably leading to turbo failure."
  • Like
Reactions: Mr. Bean
It may be a statement but that is how I have done the service for the last 40yr never had a problem.
Does any one on the forum with a turbo .after a run how many let there engine idle for a minute to allow the turbo to slow down .the oil change comes on after the last service whether you have done a 1k or 100k it is pre set to come on
thank you swinton. joe
And those were all turbo engines?
oil is good for 20k
For long tourers maybe. But short distance drivers put a lot of strain on the oil due to the thinning of petrol. And then it can be finished much earlier. Such statements are problematic!
1 - 10 of 10 Posts
