1 - 20 of 20 Posts
Does anyone know what the differences are between the Navi 600 & 900 and whether its possible to upgrade via software or is it a different hardware unit?
I seem to think the Navi 900 has 3d maps and full voice control where as the 600 has 2d maps and only phone voice control.
Chris
Anyone who has the navi 600 can you change the units from
KM to miles I.e for the voice guidance aswell.
Is it in settings or is it a dealer job
Expect it to be in the setting menu of your navi 600
Settings in the Info-Display
Navi 600
Press the CONFIG button. The menu Settings is displayed.
The following settings can be selected by turning and pressing the multifunction knob:
–  Languages
–  Time & Date
–  Radio settings
–  Phone settings
–  Navigation settings
–  Vehicle settings
–  Display
have a look in manual
http://www.vauxhall.co.uk/content/dam/Vauxhall/Europe/united_kingdom/nscwebsite/uk/Home/pdf/Owners_Services/owners_manuals/Meriva_Infotainment_Manual_Jan_2013.pdf Edited by: Moss
As I thought you need to look at your DIC!
.... That is your Driver Information Centre, the display next to the speedo.
Selecting menus and functions
The menus and functions can be
selected via the buttons on the turn
signal lever.
Press the MENU button to switch
between the menus or to return from
a submenu to the next higher menu
level.
Turn the adjuster wheel to highlight a
menu option or to set a numeric value.
Press the SET/CLR button to select a
function or to confirm a message.
Vehicle Information Menu
Press the MENU button to select the
Vehicle Information Menu, or on
Uplevel-Combi-Display select the car icon
Turn the adjuster wheel to select a
submenu. Press the SET/CLR button
to confirm.
Follow the instructions given in the
submenus.
Possible submenus can be,
depending on the version:
–  Unit : displayed units can be changed
mine is also navi 600 but i cant figure out how to enable the front collision alert, lane departure warning and the traffic sign assist. i was thinking its on navi 900. i have a front camera and satnav. and also the satnav doesn't say the speed limit unlike in garmin.
i have read the manual from top to bottom also the pdf version of it from opel. lol. the dealer says it might need upgrade or something. ill try to go to vauxhall this weekend.
Sat nav sorted now it corrected itself.
Still think collision alert not working as it should
no warning or audible alert just a green car on dash.
Discussion Starter · #12 ·
I emailed navteq and vcs about upgrading and whether sd card from 900 would work in 600. Navteq said to contact vauxhall amd vcs said to contact my dealer so I don't think they know themselves.
Would be good if someone has sd from 900 can try it in 600 and let us know if it works.
Pocco87 said:
FireEye37 said:
Hi, I use a 900 card (complete Europe) in a Mokka navi 600 and it works fine.
Don't know however how to change to 3d.
Hey FireEye37,
Can you confirm if audible alerts/my POIs are voiced?
+1
I also use the 900 card, and can confirm it does not change the functionality of the 600 i.e. you cannot get audible alerts for POI's (and I have added speed camera's to mine), you cannot get the '3d' display.
Thanks for the confirmation pk-7
Bought the full Europe SD card for the Navi900 on Monday.
Got an email from Navteq telling me that the SD card will work from the Navi900 in the Navi600 if anyone wanted confirmation.
It only took them 3 weeks to respond to my question.
VSC said they arent compatible so I think I need to enlighten them. Edited by: Ixasio
1 - 20 of 20 Posts
