Help - just got 1.7 cdti techline - trying to find my way around the menus - Read in the manual that you can change the way the doors are locked, activate/deactivate auto locking when on the move adjust ambient lighting /leaving home lighting etc. When I go into vehicle settings and comfort on the navi 600 there are no options to adjust these- Am I being stupid or are these not available on the techline model - any help appeciated
Thanks for that - to be honest can't remember if the ignition was on or not as wasthat made up to get the car I was like a kid in a sweet shop . I know the engine was not running when I was fiddling. Will give it a go tonight
Have you used the config button on the NAVI600 control panel, that should give you the options, then you use the centre button 8 way switch, turn and push outer ring
