1 - 1 of 1 Posts
Discussion Starter #1 (Edited)
1216
1218
1219
1220
1221
1225
1222
1223
1224
Execution: Edition
Engine: 1.4Turbo, EcoFlex, Start-Stop (140PS, 200Nm)
Transmission: 6-speed manual switch, FWD
Color: cream white metallic pearl effect.
Wheels: 7 J x 18 light alloy wheel, 5-spoke design (sterling silver) with Continental 215/55 R18 tires
• Exterior mirrors, electrical, heated, manually foldable, exterior mirror housing in body color
• Direction indicator, on the side
• On-board computer with check control system
• Roof rails
• Double tone horn
• Window lifter, electrical, passenger, with tip function and pinch protection
• Power windows, electric, driver, with tip function and pinch protection
• Window lifter, electric, rear
• Speed controller: cruise control and limiter
• Rear window wiper system
• Upshift recommendation in the tachometer (depending on the engine)
• Large instrument display
• Air conditioning
• Front headrest, height and tilt adjustable
• Leather steering wheel including remote control
• Steering column, adjustable in height and length
• Make-up mirror in sun visors, illuminated Standard for viewing package
• Rear fog lamp
• Pollen and activated carbon filter as standard for air conditioning
• Rear seat back can be folded forward in a ratio of 60:40
• Rear view mirror, inside, automatically dimming and automatically controlled console lighting. Standard for view package
• Headlight range adjustment, manual
• Key, foldable
• Visible exhaust tailpipe, chrome-plated
• Solar Reflect windshield
• Pocket on the back of the front seat, passenger
• Outside door handles, in body color
• Rear door handles, inside, chrome-plated
• Tinted heat-insulated glass
• Central locking with radio remote control
• Including lockable fuel filler flap for central locking with radio remote control as standard
• Airbag deactivation on the passenger side (control via switch)
• Anti-lock braking system (ABS) electronically controlled
• Automatic low beam as standard for the viewing package
• Three-point seat belts on all seats belt force limiters and pyrotechnic belt buckle pretensioners as well as double belt tensioners, front and seat belt warning on all seats
• Electronic stability program (ESP®) excl. Downhill and downhill assistant
• Electronic Stability Program Plus (ESP®Plus) incl. Hill descent and hill start assist
• High-beam assistant as standard for the vision package
• Front and side airbags, front, and curtain airbags, front and rear outside
• Belt force limiter and double belt tensioner, front passenger
• Seat belt warning, passenger
• Belt warning, driver
• Seat belt warning, back seat
• Halogen headlights
• Fog lights
• High beam assistant for autom. Switch between high and low beam
• Rain sensor as standard for the vision package
• Tire pressure control system
• Daytime running lights
• Preparation for ISOFIX child seat fastening system, rear outside
Special equipment:
Black leather interior. This means that the AGR seats are height-adjustable on both sides
Winter package (seat heating, steering wheel heating)
Radio Navi 950 Europa IntelliLink, digital radio reception DAB +
Foldable mirrors
Rear camera
Park pilot
Electrical package
Emergency wheel
carpets
Tuning:
Chrome license plate holder
Stainless steel bumper protection
Stainless steel door sills
Chrome ring around the cup holder in the center tunnel
Painted brake calipers
Winter tires: Dunlop 235/50 R18 97 V SP WINTER SPORT 4D MFS M + S on the 7 "* 18" rims
Summer rims: Autec 8x18ET35 with the original 215s. Cloned tire pressure sensors.
Eibach 15mm wheel spacing per wheel for Summer and Winter rims
LED parking lights / daytime running lights for whiter light
Foiled underride protection (brushed Titanium)
Custommade RIPS summer floor mats anthracite
Custommade Velur winter floor mats black
Chrome decorative ring around the ignition lock,
Chrome trim ring around the TMT speakers
Chrome decorative ring around the mirror plate
Chrome attachments on the window switches
Stainless steel pedal pads
Low beam: Philips X-tremeVision + 130%
Audison DSP amplifier Prima 8.9 bit
All doors acustic damped
Rainbow Germanium GL-C6.2 Active loudspeakers, tweeters in the A-pillars geared towards the listener
LED license plate lighting
LED in the ceiling lamps, the make-up mirrors and in the trunk lighting
LEDs in the reversing lights
Hood lifter / gas pressure springs for the hood
Voltmeter with 2.1A USB charger in the cigarette lighter
foiled engine cover
Changed lettering on the rear
OPC Rear Spoiler
OPC Side Skirts
Friedrich Gruppe A DUPLEX exhaust system for OPEL MOKKA with tail pipe variant 89/90
Double quick charger in the center console compartment
K&N sports air filter
Ambient lighting in the center console
LED indicators
Double USB-C quick charger in the center console compartment
1 - 1 of 1 Posts
