1 - 7 of 7 Posts
Hi Everyone,
has anyone removed the Diesel Fuel Pump from the Fuel tank of a Mokka X.
Does this pump have an internal filter fitted and does it get blocked with Supermarket Diesel.
Any help appreciated.
Hi. Not sure about the answer on your question but i changed fuel pump in a new Mokka bcs. it was producing noise. Now, after couple of months of use (5000km) this replacement pump makes noise again. Something is very wrong with those pumps. What's your problem with a pump?
Can you give any info on how you accesses and replaced the pump? I think mine needs doing but can’t figure out how to get to it
No, because offical service did that, but i'm also intersted on how to remove the pump from inside. It's located under the back seat but there is no oppening in carpet so i'm not sure how to remove carpet. Anyone knows?
Newbie here, I have a Mokka SE 1.7 cdti Automatic 2013 & I'm getting error P0113 (Intake Air Temperature Circuit High Input ) which shows every morning as 'Service Vechile Soon'. From looking online, this sensor is part of the fuel pump assembly. I've lifted the carpet under the rear seats but can't see any fixings. Any help appreciated
There is some brief information HERE
1 - 7 of 7 Posts
