had my 64 plate 1.7 mokka a week and noticed the water level going down by as much as 1cm over a 3 day period .
just looked under bonnet and is this coolant guys ? ( pics )
when engine is running its a steady drip every 2 seconds or so .
if this is the issue ..is it expensive or difficult to fix by myself ? cheers
Which engine is itv.are there 2 leaks or one .one looks like it’s going to heater the other is under the expansion bottle .how much water are you loosing from expansion bottle
its going back to dealer next week pal.
its a 1.7 d .
top hose is leaking right at bulkhead and losing roughly 10mm every 3 days .
tried uploading a video but forum wont let me
No problem.hope you get it sorted
Morning
Did you get the issue sorted
I had exactly same issue with my Mokka in short an o ring inside the connector to the heater matrix inlet had slightly degraded The garage I use just replaced the o ring ,topped up coolant and all done
Couple of weeks later the second pipe suffered exactly the same issue so I sourced the corrrect size o ring and fitted it myself.
If it’s under warranty get them to fix it
Morning
What was the size of the O ring?
