1 - 5 of 5 Posts
can anyone help me .
I need to remove the heater blower motor from under the glove box.
the workshop manual say undo 3 or 4 screws and drop the motor out.
I have done that but there is no way the fan will fit though that small gap cant evan get my fingers round the motor to pull it out.
there has to be another way around this. 1.7cdi 13plate
Assuming you have removed the following Glove box, lower facia, lower foot well trim, footwell air duct, wiring plug from resistor. Resister optional (more wiggle room) If all screws removed it should come out.
I have not actually removed the motor only the resister unit. From what I remember don,t know why motor not coming out?
Don’t you need to uncouple the heater maxtrics .i would think it all comes out in one unit
Discussion Starter #4
yep removed every thing. there is no mine will come out in one piece
Just had a look behind the glove box. You may have already tried this?
Removed the strengthening bracket what the glove box fastened too 2 bolts either side and cable strap Remove the pollen filter get your hand in to try to push the fan unit out
1 - 5 of 5 Posts
