1 - 4 of 4 Posts
My mokka se is back in for repair after first having new head light then crank shaft oil seal replaced after leaking oil over the drive now making a hissing noise from rear they said it sounds like fuel pump how many problems can one have on a new car
Discussion Starter · #2 ·
Just a update Arnold clark repaired my oil leak then the car had a noise from the fuel pump area. After 1 week they said they don't no what it is so I called in the vauxhall technician which took another 2 weeks. he said it the characteristics of the car.so they made a fault and now not owning up to it I'm shore this is a cop out be warned. Going to let them keep it
Good morning all, has anyone had to replace the fuel pump on their momma? If so was it very expensive? Thank you
1 - 4 of 4 Posts
