1 - 3 of 3 Posts
Hello,
I am having a problem with my Mokka 1.7cdti 2014.
The fuse F6 ( interior light) is continuosly blowing off.
I troubleshooted the issue and I found that fuse F6 is short circuited with fuse F1.
The maual is describing that fuse F1-F8 are " body control module" .
Does anyone know what exactly fuses from F1 toF8 are suppling??
Thanks for
Hello,
Thanks for
From the battery, the fuses are not short circuit, they receive, current from a common rail, which is positive battery terminal,, all the fuses from f1 thru f2, f3, f4,, f5, f8, f6, f7, f19, feed body control module, you may have faulty body control module, see if its possible to replace, check your fuses to see if they are of the right amperage, f6=15amps etc, if you put 10 amps fuse in it will blow, when you operate light, make sure you take them out one at a Timeand the are in the right place.
See Attached Fuse / Relay List "Sorry put page 2 upside down"
1 - 3 of 3 Posts
