1 - 7 of 7 Posts
Any help would be appreciated. 1.6 petrol engine fires up fine, but stalls at junctions whilst it is cold. Fine once it has warmed up. Changed Lama sensor, mass air flow sensor, external temperature sensor. No faults on diagnostic computer. Been to 2 garages and they can't find the solution. Please help
Do modern cars still have automatic chokes .or is controlled by the ecu now .could that need updating/reprogramming.just a thought
Not sure if the 1.6 has an intake air temp sensor, if it does well worth changing, they are only cheap.
Thought the inlet air temperature was measured by the MAF these days.
The 1.6 petrol Astra had a temperature sensor in the plastic tube from the air cleaner, don't know if it still has or if the 1.6 Mokka has one, hence why I said not sure is it has one.
I don’t know either but can usually tell if the MAF has an IAT bulb by looking at the connector (more wires). Hard to remember which car has which these days and as someone once said With the electronic gubbins on modern cars, most of the time when you get a warning light on there's nothing wrong with the thing that’s being monitored. It's the thing that's monitoring the thing that's actually gone wrong.
1 - 7 of 7 Posts
