1 - 4 of 4 Posts
Hi, first post so please be gentle.
My wife has a Mokka 1.4SE petrol and it has done just under 30k.
It has a small oil leak which has dispersed itself as a spray all over the top half of the engine. It is as if someone has sprayed it with an aerosol and just wondered if anyone else had suffered anything similar. I know I can clean it off and look for a leak but as it it is so fine it may still be difficult to find where it's coming from and the fact that the oil level is still ok means it isn't losing much.
If anyone has had a similar issue and found the cause I would be grateful.
Cheers guys
Is the oil cap loose?
Discussion Starter #4
Thanks guys, I will go and check. I have had a look obviously but can't see where it is coming from. Its possibly being released from somewhere under a fine pressure but just wondered if anyone else had had the issue. I will check the cap.
1 - 4 of 4 Posts
