1 - 7 of 7 Posts
Had an ongoing problem with Mokka 1.6d the egr valve stopped working I changed this and all seemed good, then light came on again had a look at the egr valve working ok. the n noticed on the bottom of the egr cooler there seems to be a plunger of types that springs out when engine revs.
Belive this is supposed to be attached to a sensor arm that is missing?
The car went into Vauxhall a few months ago to have the clutch slave cylinder replaced under warranty, wonder if they broke this off in process as they replaced the clutch too.
My main problem is there appears to be no info available anywhere on the 1.6d ecoflex engine has anyone any info on the egr cooler of a manual to download or where can buy one from.
1 - 7 of 7 Posts
