Superkev said:
I was driving in front of my wife in her mokka today and realised that whenever she indicated the drl switched off on that headlight???? .
When I fitted the mirror indicator bulbs for
http://www.mokkaownersclub.co.uk/forum/bulb-fitment_topic233.htmlI thought I had bu66ered the DRL, yes indicator cancels DRL on that side.
Also on Automatics DRLs dont light in 'park' when engine running.
<div align="center">14 June 2010
AGREEMENT
CONCERNING THE ADOPTION OF UNIFORM TECHNICAL PRESCRIPTIONS
FOR WHEELED VEHICLES, EQUIPMENT AND PARTS WHICH CAN BE FITTED
AND/OR BE USED ON WHEELED VEHICLES AND THE CONDITIONS FOR RECIPROCAL
RECOGNITION OF APPROVALS GRANTED ON THE BASIS OF THESE PRESCRIPTIONS
UNIFORM PROVISIONS CONCERNING THE APPROVAL OF VEHICLES WITH REGARD
TO THE INSTALLATION OF LIGHTING AND LIGHT-SIGNALLING DEVICES
UNITED NATIONS
6.19. DAYTIME RUNNING LAMP (Regulation No. 87) 13/
6.19.7. Electrical connections
6.19.7.1. The daytime running lamps shall be switched ON automatically when the device
which starts and/or stops the engine is in a position which makes it possible for
the engine to operate. However, daytime running lamps may remain OFF while
the automatic transmission control is in the park or neutral position, while the
parking brake is applied or after the propulsion system is activated but the vehicle
was not set in motion for the first time.
The daytime running lamps shall switch OFF automatically when the front fog
lamps or headlamps are switched ON, except when the latter are used to give
intermittent luminous warnings at short intervals. 14/
Furthermore, the lamps referred to in paragraph 5.11. are not switched ON when
the daytime running lamps are switched ON.
6.19.7.2. If the distance between the front direction-indicator lamp and the daytime running
lamp is equal or less than 40 mm, the electrical connections of the daytime
running lamp on the relevant side of the vehicle may be such that either:
(a) It is switched OFF; or
(b) Its luminous intensity is reduced during the entire period (both ON and OFF
cycle) of activation of a front direction-indicator lamp.
6.19.7.3. If a direction-indicator lamp is reciprocally incorporated with a daytime running
lamp, the electrical connections of the daytime running lamp on the relevant side
of the vehicle shall be such that the daytime running lamp is switched OFF during
the entire period (both ON and OFF cycle) of activation of the direction-indicator
lamp.
Edited by: Blum
