1 - 20 of 118 Posts
I've just got a Nexus 4 and wondered if it works ok with the Mokka.
Anyone have a Nexus 4.
Also what phones do people have and is it fully working with your Mokka.
Won't be able to test mine until around May/June delivery time.
Samsung Galaxy S3 pairs, transfers directory, but when it 'locks screen' after the first call it disconnects.
Awaiting answer from Samsung, the answer is
Settings -
Advanced -
Stay awake , screen will never sleep while charging.
Then plug in the car charger every time you get in the car.
Not ideal, but it works......
Settings -
Advanced -
be careful of screen burn on the Galaxy S3...
And an answer floods in, (and you thought the lighting regs were boring!)
"<!--if gte mso 9>
<o:OfficeSettings>
<o:AllowPNG/>
</o:OfficeSettings>
<!-->Thank
you for contacting Samsung.
I'm sorry you are experiencing problems with Bluetooth on your device. I can
understand your frustration about this.
In regards to your query, the issue is usually due to how the Android OS
communicates with Bluetooth. Android software is Open Source, but Bluetooth
profiles are not, which means the Android OS doesn't use the same profiles that
are required for a lot of cars.
The most common Bluetooth profile that car manufacturers use is called ""˜rSAP',
but unfortunately Android does not support this profile at this time. This
means that car communication may be hard to achieve since this profile is
designed to allow full control of the phone through another Bluetooth device.
Please try the following process, as sometimes it will make an improvement on
the connection, depending on which profile your car uses:
1) Turn on Bluetooth
2) Go to Settings > Applications > Running Services > Look for
""˜Bluetooth share' (there should be at least two) and select the first one
3) Under ""˜Services' at the top of the screen it should read
""˜BluetoothPbapService', if it says this, please select ""˜Stop', if it says
something different, try the next ""˜Bluetooth share' under Running Services
All our phones support Bluetooth profiles, so this process will attempt to stop
the Android OS controlling the Bluetooth and allow the device to control it
instead.
This will need to be performed every time Bluetooth is connected to your car.
If this does not work then the issue may be addressed in a future Android OS
firmware update.
Please note we cannot guarantee compatibility with all cars, or car kits. You
may wish to check with the manufacturer of your car, or car kit, for further
advice on troubleshooting your problem. They may have a specific process you
need to follow in order for your car to communicate with your device properly.
I've passed your comments on to our software development team to help improve
the connectivity of our devices. Thank you for your input.
If you require any further assistance, please contact Samsung again and we will
be more than happy to help.
Kind regards,
Helen
Online Support Team
SAMSUNG Customer Support Centre "<br style="mso-special-character:line-break">
<!--if gte mso 9>
<w:Word>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves/>
<w:Trackatting/>
<w:punctuationKerning/>
<w:ValidateAgainstSchemas/>
<w:SaveIfInvalid>false</w:SaveIfInvalid>
<w:IgnoreMixed>false</w:IgnoreMixed>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:DonotPromoteQF/>
<w:LidThemeOther>EN-GB</w:LidThemeOther>
<w:LidThemeAsian>X-NONE</w:LidThemeAsian>
<w:LidThemeComplex>X-NONE</w:LidThemeComplex>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:DontGrowAutofit/>
<w:SplitPgBreakAndark/>
<w:EnableKerning/>
<w:DontFlipMirrorIndents/>
<w:OverrideTableStyleHps/>
</w:Compatibility>
<m:mathPr>
<m:mathFont m:val="Cambria Math"/>
<m:brkBin m:val="before"/>
<m:brkBinSub m:val="--"/>
<m:smallFrac m:val="off"/>
<m:dispDef/>
<m:lMargin m:val="0"/>
<m:rMargin m:val="0"/>
<m:defJc m:val="centerGroup"/>
<m:wrapIndent m:val="1440"/>
<m:intLim m:val="subSup"/>
<m:naryLim m:val="undOvr"/>
</m:mathPr></w:Word>
<!--><!--if gte mso 9>
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemi="true" DefQat="false" DefPriority="99" LatentStyleCount="267">
<w:LsdException Locked="false" Priority="0" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Normal"/>
<w:LsdException Locked="false" Priority="9" Semi="false" UnhideWhenUsed="false" Qat="true" Name="ing 1"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 2"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 3"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 4"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 5"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 6"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 7"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 8"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 9"/>
<w:LsdException Locked="false" Priority="39" Name="toc 1"/>
<w:LsdException Locked="false" Priority="39" Name="toc 2"/>
<w:LsdException Locked="false" Priority="39" Name="toc 3"/>
<w:LsdException Locked="false" Priority="39" Name="toc 4"/>
<w:LsdException Locked="false" Priority="39" Name="toc 5"/>
<w:LsdException Locked="false" Priority="39" Name="toc 6"/>
<w:LsdException Locked="false" Priority="39" Name="toc 7"/>
<w:LsdException Locked="false" Priority="39" Name="toc 8"/>
<w:LsdException Locked="false" Priority="39" Name="toc 9"/>
<w:LsdException Locked="false" Priority="35" Qat="true" Name="caption"/>
<w:LsdException Locked="false" Priority="10" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Title"/>
<w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/>
<w:LsdException Locked="false" Priority="11" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Subtitle"/>
<w:LsdException Locked="false" Priority="22" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Strong"/>
<w:LsdException Locked="false" Priority="20" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Emphasis"/>
<w:LsdException Locked="false" Priority="59" Semi="false" UnhideWhenUsed="false" Name="Table Grid"/>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/>
<w:LsdException Locked="false" Priority="1" Semi="false" UnhideWhenUsed="false" Qat="true" Name="No Spacing"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 1"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/>
<w:LsdException Locked="false" Priority="34" Semi="false" UnhideWhenUsed="false" Qat="true" Name="List Paragraph"/>
<w:LsdException Locked="false" Priority="29" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Quote"/>
<w:LsdException Locked="false" Priority="30" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Intense Quote"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 2"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 3"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 4"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 5"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 6"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/>
<w:LsdException Locked="false" Priority="19" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Subtle Emphasis"/>
<w:LsdException Locked="false" Priority="21" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Intense Emphasis"/>
<w:LsdException Locked="false" Priority="31" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Subtle Reference"/>
<w:LsdException Locked="false" Priority="32" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Intense Reference"/>
<w:LsdException Locked="false" Priority="33" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Book Title"/>
<w:LsdException Locked="false" Priority="37" Name="Bibliography"/>
<w:LsdException Locked="false" Priority="39" Qat="true" Name="TOC ing"/>
</w:LatentStyles>
<!--><!--if gte mso 10>
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-hansi-theme-font:minor-latin;
mso-fareast-language:EN-US;}
Mine pairs to both an iPhone and a bog-standard Nokia no problems. The voice recognition is the main irritation for me. It will only allow you to say 1 word at a time. For example, rather than saying "Call Home", you have to go through the routine of "Call." "Please say the name to call" "Home." It then checks to make sure you want to call Home, then cannot understand "Yes"!
DietCokeBloke said:
We'll have to wait for him to wake up after reading it and try it.
Flat Eric said:
Do not disturb
Yawn............
It did work, but if they think I'm going through hat palaver every time I start the the car they have another think coming.
As for screen burn psp888, on keep screen alive when charging, it is alive but very dim.
Samsung blame Android for the problem, you seen how many Samsungs are Android?
Discussion Starter · #12 ·
Blum said:
Flat Eric said:
Do not disturb
Yawn............
<span id="userPro5" ="msgSidePro" title="View Drop Down"></span>
Samsung blame android...? Why does the One X and S2 work pefectly ok from what other users have said.
"<!--if gte mso 9>
<o:OfficeSettings>
<o:AllowPNG/>
</o:OfficeSettings>
<!-->Thank
Thats how I read it.
thats exactly the problem (and solution) I have using my S3 in my Renault Megane with its fully intergated phone system blah blah blah.
however, had an SE Experia Arc (Andriod) before and it worked perfectly. That response from Samsung is tosh, its not as simple as that!! I read a guide to bluetooth and fully compatiblephones in the Mokka and the S3 wasn't listed because of the bluetooth system it uses. mentioned it to my dealer and said it won't work effectively but he said he could set up for me. I know he won't be able to, he's 2 vowels away from a twit!!
1 - 20 of 118 Posts
