1 - 8 of 8 Posts
Hi gUYS
Can any help with how to disable the annoying sat-nav voice?
Many Thanks.
Why not just turn the volume down?
Black Mokka X 1.4 T Active 2019 {from new}
Adjusting the Navigation Volume
Press the CONFIG button and then select the Navigation Settings menu item.
Select the Navigation Volume menu item. The respective submenu is displayed.
To adjust the volume of the announcements, select
Announcement and then adjust the setting as desired.
Have you tried this?
Taken from owner manual, will not affect other audio level.
Much Appreciated
And if I want to listen to the Radio?
The radio is on a different volume setting and will not be affected, same with in-coming phone calls. All audio adjustments are independent of each other and should be adjusted likewise i.e. as the Nav voice is talking to you.
1 - 8 of 8 Posts
