1 - 18 of 18 Posts
from the last 3 weeks something has happened when i am going to work in the morning i started my mokka the dash flickers specially on the climate controls. this morning when i started the car it beeps continuously the same beep when you go beyond your speed limiter. Anyone had experienced this?
the only solution is to turn of and on the engine. which is a bit worrying for a new car.
Take it in for a reset or reset it your self remove the battery for a min.
When we picked up the Mrs brand new VXR everything on the dash lit up nothing worked oops i said so walked back into the stealers all they done was remove the battery lead for a min that reset every thing never had a problem since.
Happy days
I have mentioned elsewhere the potential problem of disconnecting the battery i.e. the engine will not start
I thought I was the only one that had noticed the flickering backlights on the climate controls
Dealer has been in contact with Vauxhalls tech guys, who were stumped as to how to sort.
They've tried swapping out the climate control unit with another Mokkas, still flickered.
Tried reprogramming the ECU, and it still flickered.
Then the technician had a brainwave; he disconnected the alternator and it stopped, re connected and it started again.
So its booked in to have the alternator changed next week as the part is on back order. Will update on here once its done
Its what comes of being Beta testers of a brand new model
So far I've had the AFL issue, the chrome bubbling up on the fog light trim and this.
All in 8500 miles
1 - 18 of 18 Posts
