1 - 20 of 123 Posts
A thread that is always handy to have for a vehicle in general so as its updated i'll update initial post with bulb types.
So if you know what bulb fitments they are in the Mokka please let me know (I'm mainly posting as I want to get some silvertech indicator bulbs in asap, hate yellowness / orangeness)
AFL Headlights:
Sidelight / DRL - Inbuilt none replaceable (as far as I am aware)
Indicator - T20 Amber Capless
Dipped Beam / High Beam / Dancing AFL- D3S Xenon bulb (
Turning Light - H11
Halogen Headlights
Sidelight / DRL - T20 580 7443 W21/5W Dual filament
Indicator - T20 Amber capless 12v/21w
Dipped Beam - H7
High Beam - Sylvania HB3 U 12v 60w
Foglights
Front - H11
Rear
Tail Lights
Stop & Tail - T20 580 7443 W21/5W Dual filament
Reverse - 12v 16w (Could be called T15, photo further on in thread)
Number Plate - T10 12v 5w
Interior Lights
Boot light - T10 / 501 w5w, lateral to boot panel, no reflector behind.
Interior roof bulb - Festoon 264 42mm 10w
Front Reading bulbs x2 - T10 / 501 w5w, pointing down with reflector behind.http://www.ebay.co.uk/itm/UK-Stock-...arts_Vehicles_CarParts_SM&hash=item4ac0a96282
Info curtesy of blum / Andy H
Edited by: Andy_H
Rear bulbs. Not how it looks in the handbook!!!!!
Photo is of right side (Offside UK)
Remove the storage door, (and the tyre repair kit if fitted)
Remove light cover, large bladed screwdriver (or ignition key).
You will see
They are all Wedge type bulbs, holder can be removed by thumb turn, about 30 degrees anti clock.
Not a lot of cable for manouvering!
Edited by: Blum
Hi, can you also check what bulbs are used for the interior lights and boot light please.
would like to get some leds ordered ready to be fitted even though I have 4 month wait still.
thanks
It might be better to pull all the lighting info into one thread that is stickied instead of lots of separate ones.
Mr Mayo - apart from looking a bit more blue is there that much difference?
No problem with bulb errors then? I tried this with my Astra and it would always throw up a bulb error as the Led uses less power
<!--if gte mso 9>
<o:OfficeSettings>
<o:AllowPNG/>
</o:OfficeSettings>
Here are the the DRL and indicator changes in one place.LEFT - Standard DRL vs RIGHT Piaa T20 Mirror (doesn't look as bright as it is, camera decided to use flash!)
LEFT - Standard T20 Amber (fried eggs) vs RIGHT - Xtec wy21w T20 Chrome Amber unlit.
LEFT - Xtec wy21w T20 Chrome Amber lit vs RIGHT - Standard T20 amber lit.
Changed Standard dipped beams to Ring xenon ultima +120%, cant see much difference in daylight.
Edited by: Blum
1 - 20 of 123 Posts
