Automatic lighting, so what gives?
26K views 20 replies 12 participants last post by  starlitz
Ixasio said:
It should work, it took me a while to work it out when I first got my car
Did your dealer not explain to you how it worked.
Must admit that I do not use it a great deal at his time of year but......... as the dark nights draw in. When I have used it it has worked a treat. No one flashes you if you inadvertently forget to switch your main beam down, which we have all done at some time or another.
Edited by: Mokkadna
DietCokeBloke said:
The only problem is when you're on a dual carriageway with a central reservation where the auto beam kicks in and is fairly late to switch off with a car coming in the opposite direction.
Not been on a dual carriageway in the dark yet. Will have to remember to check for that.
