1 - 9 of 9 Posts
My Air Con just blowing cold air. Fans controls all working.. Just cold air no matter what setting!?!
Is it just fuses??
Any help appreciated before sending to mechanic.. ☺
Mine does not blow ice cold .do you turn the temp setting to cold
I'm confused, air con is meant to blow cold, are you saying your heater will not blow warm?
Discussion Starter #5
Sorry Air Con was wrong title.. YES internal heating or climate control (not aircon)... I need heat in this car for the shitty weather to come!
Do I check fuses 1st (ie F12).. or is it more serious? 🤔
So the heater will get warm but the fan won't blow? If so, fuses is the place to start, next thing I would check, depending on your electrical ability, is the fan resistor pack
Discussion Starter #7
No... The FANS are all working.. Just blowing cold air into car no matter if I turn heating full. Fuses? or something else is the question.. 😕
Ah, OK, in that case, first thing to check is your coolant level, if the tank is empty check for leaks, correct the level, with 50/50 anti-freeze, run the engine at fast idle with the cap off and keep checking the level till its at normal temperature, when it's cooled check and final top up.
Would be nice to get an update sometimes, just to know if any advice given had helped or not!
1 - 9 of 9 Posts
