at 60,000 miles i think the oil in the rear axle should be changed, but what grade should i use.?
Does it matter as long as you have the right oil specific
Correct, that weight doesn't give which specific kind of differential oil you should use. Look it up there's different versions, do you know whats inside compared to the gearbox?
