1 - 10 of 10 Posts
Hello all
I love my Mokka, I really do. More than any other car I've had, and there's been a few.
But, it's making me cry.
It started around November last year, just a very slight rattle on start up. It's got progressively worse.
Sometimes, it sounds quick nasty, very metallic and angry. it only lasts for less than a second and then it's as normal as can be.
it happens when the engine is warm now too, but not as bad. It's worst when cold.
It used to be be every couple of days but now it's every time.
I've searched the forum and found some threads not directly linked to my engine that would put the issue at the timing chain tensioner.
Car has done just under 50k, it's a 2015 plate
What am I looking at here? new chain? ist that an engine out job?
Anyone had it done? how much was it?
thanks
Jase
You describe it as "A rattle, metallic and angry" which without actually hearing it would require a guess.
I recorded this today, it's from cold. It's having a good day, it's been worse than this recently.
Very difficult because with a recording there is no sense of where the sound is coming from, but to me it sounds like a tappet/valve lifter leaking down.
that sounds like a less depressing possibility.
any sure ways of testing for that?
Normally I would say place a long screwdriver on the cylinder head at various points while resting your ear on the handle end, but your noise is not lasting long enough to try that, on high mileage cars I have just changed the oil to 20/50 and it's stopped it permanently, but your mileage is relatively low. When your next oil change is due it might be worth trying 20/50 for a week or so, to see if it stops it, then change back to the correct oil. if the noise stops completely you know its a leaking tappet. The reason thicker oil often stops the noise is simply that it can't leak past the seal so easily.
Bum, I've literally just had the oil changed in the last month.
Have you found any solutions my mokka is doing similar but worse until its driven/reved.
From what i have read and heard elsewhere, the 1.6 cdti seems to be getting a reputation for
rattling or knocking timing chain's/ tensioner's as the miles creep up.
Discussion Starter · #10 ·
No solutions sadly, I've been flat out with work at the moment so have had no time to even think about it.
1 - 10 of 10 Posts
